2004 sportsman 700
Old Mar 17, 2008 | 08:59 PM
CRISCO's Avatar
Default 2004 sportsman 700
when the atv is running i can not change gears, and it goes by itself. when the atv is off i can change gears. can anyone tell where i can start wtih this problem.
Old Mar 17, 2008 | 09:00 PM
polarisman600's Avatar
sounds like maybe your idle is set too high.
Old Mar 17, 2008 | 09:06 PM
CRISCO's Avatar
I HAVE CHECKED THAT I THINK IT MAY BE THE PRIMARY CLUTCH
Old Mar 17, 2008 | 10:23 PM
Kerbmonster's Avatar
your ebs washers are gone, defintiely primary clutch, need to take the clutch to the shop and have them go through it
Old Mar 18, 2008 | 10:51 AM
CRISCO's Avatar
will a new belt tempory fix the problem. i am going on a ride next weekend.
Old Mar 18, 2008 | 03:10 PM
no, it should only take an hour or so to rebuild the clutch, if you take it off and take it to them. if you don't fix it pretty quick, you'll wear a groove around the shaft on the inner sheave and then you'll be buying a new clutch.
Old Mar 18, 2008 | 07:25 PM
Scooba Steve's Avatar
looks like clutch time! Had the same problem....It could be the bearing under the pulley. Take clutch off, remove primary clutch, seperate pulleys,clean and grease the bearing under the sleeve that the belt rides on. Mine was rusted and broke apart and ball bearings on floor after observing bad part....$$$>300.00 for entire clutch[img]i/expressions/face-icon-small-sad.gif[/img]
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
bradco
Aug 21, 2015 08:11 PM
Stirling
Aug 9, 2015 01:49 PM
