Checking '01 engine and tranny while it's out
Old Mar 18, 2008 | 05:53 PM
TN01DS650's Avatar
Default Checking '01 engine and tranny while it's out
I took my case out last week and am having a valve job done by HPR as well as going to an 11.5:1 piston. I am also replacing the water pump shaft and seals. I learned on here that the shift problems (slipping out of 2nd, finding false neutrals occasionally) I have been having are probably the shift forks. I am also going to replace the shift forks with the new and improved versions but am not planning on getting the gears back cut since I don't drag race.
So....practically everything will be apart.
Is there anything else I should do since I have it out and apart? I will visually check everything but is there anything in particular I should pay attention to? I don't really want pull this thing out again any time soon. Thanks!! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 18, 2008 | 06:40 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
since shes already apart throw a stroker crank in there!!
Old Mar 18, 2008 | 09:02 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Even though you don't race I would have the gears back cut. It makes the tranny shift like butter. You have it apart, i think its only an extra 500 bucks.
Old Mar 19, 2008 | 08:47 AM
DS650powe's Avatar
$500 for back cut gears? wow thats a lot, how much does an override tranny cost(not that you would want one im just curious)
Old Mar 19, 2008 | 10:43 AM
MRDS650's Avatar
Not sure on an over ride tranny, keep in mind if you back cut the gears you should never have shift fork trouble again either.
Old Mar 19, 2008 | 04:30 PM
DragonDJ11's Avatar
Have your fly wheel lightened up while you are in there. Makes a huge difference in rev speed...
SOLOLUCKY
Oct 4, 2024 09:09 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
Trxoutlawz
Mar 2, 2001 09:33 AM
in2atvn
Sep 20, 2000 04:58 AM
JRM
Nov 19, 1999 01:41 PM
