97 Warrior No spark(test cdi?)
I have a 97 warrior which has no spark, I have replaced the coil to bran new and the cdi was given to me by someone who said it came out of a running warrior.Well I put the cdi in after replacing the coil and testing the wires to the cdi. I have no spark and very little to no power(1 volt) going to the coil.I have checked the whole wire harness and found nothing wrong with it. maybe a bad neutral switch but thats all.
How do I test a cdi?
What other things are normal to stop the warrior from making spark?
Could a bad neutral relay cause this ? is there a way to bypass that relay?
Can those relays be bought at an auto parts store?
I have the same problem with my 95 warrior, I have replace everything electrical and cant get spark... I think its the stator but its brand new and ohm's right... New CDI and have tried one off a running bike but no workie??
http://www.sandwizards.com/Service_Manuals/warrior.pdf Chapter 7. Check the wires in the rear to make sure they are not rubbed through to bare wire where they run around the frame. Seen it happen twice.
<div class="FTQUOTE"><begin quote>Originally posted by: FordNut5
Here is a important thing to remember, this comes from hours of frustration. Just because a parts brand new, doesn't mean its good. Any mechanic will tell you that</end quote></div>
amen....
amen....
Let me ask you guys this ; What does the back of the cdi look like? should it be smooth rubber/epoxy or does the back of a running cdi have what looks like plastic which has melted into the rubber.I have two cdi's one I thought was blown because the back rubber had small chunky looking plastic coming though it.I got another from cdi that was supose to be from a running warrior and it had some of the same stuff melted into the back. does this mean I'm waiting my time with two blown cdi"s? also would a bad neutral switch and neutral relay cause me to have no spark.
