Blaster steering column
Old Mar 19, 2008 | 11:11 AM
chuckneste's Avatar
Default Blaster steering column
Hello All,
I have a blaster as you may of seen in my previous post that has a camber issue. one front side tire is slightly more angled than the otherside.I can live with that. I also noticed with my front handlebars pointing straight, The tie rod mounts on the steering column is off center. I assume this is bent and cant be adjusted. I can make up for some of the difference if I make on tie rod longer than the other to get the wheel somewhat straight. Is this common or am I being to dam picky*l*
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Ahtatu
Sep 28, 2015 12:14 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Albertaboyy
Sep 9, 2015 09:51 AM
