95 warrior starting problems
Ok here is the deal ,started my warrior ,ran it around a little bit then changed the oil in it,started it up everthing was fine ,next day went to start it just turnt over ,fired up and then shut down,now it doesn't even turn over ,You can hear it clicking at the starter relay,so I thought I burn't up the starter,so i put a new starter on it,still the same .Does anyone know or anyone had the same problem before ,I have already checked the fuse any help would be appreciated Thanx
listen i just had that problem today, under the left fender closest to the rear of the machine is a relay for the starter [the big one] its junk. carefully cut the top off with a new razor blade and u will see a piece of metal that moves up and down push it down and hit the start button it will start right up. in the mean time while u wait for the new one stuff a piece of thick paper in it and electrical tape the piece u cut off back on a new relay cost about 30 beans and it is call the starter circut relay good luck
