ds 90 2 stroke wont run
Sounds like an air leak or lack of fuel..Check your tank for flow then the lines and filter..If that all checks out make sure the float needle assembly is clear as well as the pilot jet in the carb...Does this bike have an electric choke?..Maybe try covering the carb with your hand while cranking and see if it will start..If it does the choke is not working.
yes it do have a automotic choke but i unpludged it and took it out and stuff it seems 2 me thaat i can spray gas in the carb and she will run while i keep sprayn gas with the trottle wide open
<div class="FTQUOTE"><begin quote>Originally posted by: drew2005
yes it do have a automotic choke but i unpludged it and took it out and stuff it seems 2 me thaat i can spray gas in the carb and she will run while i keep sprayn gas with the trottle wide open</end quote></div>
Try putting your hand over the carb opening to act as a choke while cranking..Once it starts you will have to give it a little air to keep it running.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
