help my polaris
Old Mar 23, 2008 | 09:37 PM
polaris sportsman 600's Avatar
Default help my polaris
can someone help me i have a polaris sportsman 600 i was rideing it and all a suden i let off the throttle and it went full throtle i had to turn off the ignition so i wood stop brakes worked but every time i turn it on it stays hi even with the choke in or out it stays hi so can some one help me out thanks
Old Mar 23, 2008 | 10:04 PM
polarisman600's Avatar
first i would check to make sure that your etc cable is adjusted properly. not sure if that could cause it or not.
Old Mar 23, 2008 | 10:10 PM
thanks ill check that
Old Mar 24, 2008 | 02:20 PM
deanz400's Avatar
check the carb to make sure it's not stuck wide open
Old Mar 24, 2008 | 03:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you must have something wrong w/ the etc as well as it should have shut the bike down when it stuck wot. cable the cables all the way back to the carb to see if something is not catching on it holding it out.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
