ds720
Old Mar 24, 2008 | 05:31 PM
viper5683's Avatar
Default ds720
Whats happening guys
I have a 2001 ds720 with je 720 big bore kit installed. i took it on a ride last year and the nut on the head stud poped off. i fixed that and then i found out that the watter pump seals were bad and replaced them. still smoked white. i did clean the carb out and found a lot of sand in it. im just wondering is my valve guids and seals are bad and thats whats causing it to smoke white almost no color just white.
I mean it has new piston and rings new head gasket and new water pump and thermastate gaskets what else could it be.
Thanks ahead of time for your feed back.
RON WOODS PORTED INTAKE MANIFOLD (177.45)
MIKUNI TM45 CARB - (405.00)
BARNETT 9DISK CLUTCH AND HEAVYDUTY SPRINGS (199.99)
UNIFILTER (24.00)
K&N OIL FILTER (11.99)
JE 720BIG BORE KIT 105MM SLEEVE, JE 11:5:1 PISTON, RINGS, CIRCLIP, RISTPIN - (365.00)
WEB CAMSHAFTS 110 GRIND CAMS - (260.00)
WEB CAMSHAFTS RACE VALVE SPRINGS WITH TITANIUM RETAINERS - (147.00)
2004 HEADLIGHT ASSEMBLY (65.00)
RISER BAR CLAMP - (CAME WITH BIKE)
INVISION POWER SPORTS DEVOURER GRAPHICS KIT - (339.00)
WACO CLEAR RADIATOR HOSES - (100.00)
MOTION PRO TWIST THROTTLE FOR TM45 CARB - (45.00)
WOODS RACING FULL EXHAUST - (552.25)
WOODS RACING IGNITION BOX - (CAME WITH BIKE)
AC RACING NERF BARS - (CAME WITH BIKE)
Old Mar 24, 2008 | 07:19 PM
SANDMAN430's Avatar
Default ds720
white is water, head gasket is the first thought
Old Mar 24, 2008 | 08:32 PM
DragonDJ11's Avatar
Default ds720
I am with Sandman. Did you replace the headgasket after that stud bolt came off? Either way, that is the first things I would fix at this point. Make sure those parts are super clean when you re-install...
Old Mar 24, 2008 | 09:01 PM
Cardiac's Avatar
You can take all the "shootouts" and put them in one bucket and you won't have beans.
Default ds720
Sounds like a head gasket to me also. Make sure the head is perfectly flat and torque the bolts in the correct order and sequence. BTDT.
Old Mar 25, 2008 | 12:36 PM
viper5683's Avatar
Default ds720
thanks guys I ordered my cometic gasket top end kit today should be in in about 2 weeks also while the head is off i might as well have them lapp the cylinder deck and the head and im going to replace the valve guids and seals.
BigCquadguy
Nov 28, 2009 12:31 PM
ERBEDS650
Jul 18, 2007 01:12 PM
ANNIHILATER
Jul 10, 2003 09:43 PM
14mins
Jul 8, 2002 10:33 PM
