Weird.My choke is extremely hard to pull out.
Old Mar 24, 2008 | 11:53 PM
nathanpri08's Avatar
Default Weird.My choke is extremely hard to pull out.
My choke on my 2005 ds is seriosly stuck.I put some lucas grease on the choke lever and no luck.So maybe its inside the carb??I actually have to use vice grips just to pull the choke out to start.It goes in easy thow.Any ideas, the vice gripp are a pain..Info well apreciated.
Old Mar 25, 2008 | 09:49 AM
BioWare's Avatar
Toxic Ryder
MIne got hard to pull too. I used some carb cleaner and it seemed to do the trick. But it seems to do it after every wet and muddy ride, just repeat process " Carb Cleaner"
Old Mar 25, 2008 | 10:45 AM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Pull the choke plunger out of the carb.
Clean the plunger with carb cleaner and then spray and wash out the cavity in the carb that the plunger goes into.
Wipe off excess cleaner so as not to discolor any metal.
Spray WD-40 into cavity and onto the plunger. Reassemble.
Do this twice a year.
Replace the factory breather tubes that run on each side of carb and are tied together above the carb. Buy enough and re-route the tubes down to the swingarm hole where the carb overflow tube exits. Tie the two tubes together just in front of hole.
skinnyr6
Aug 25, 2023 02:18 AM
toonces
Oct 16, 2019 12:11 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Shifts
Jul 3, 2015 07:59 AM
