HOT RAPTOR
Old Mar 25, 2008 | 02:58 PM
king_kval's Avatar
Default HOT RAPTOR
has anyone ever had a problem with the fan not working on a 660 raptor,and if so what did u do to fix it??????????????????????????????/
Old Mar 25, 2008 | 05:47 PM
recon99's Avatar
Default HOT RAPTOR
The first thing to check is if the fan works if you attach it directly to power. If the fan runs when connected directly to the battery or another power source, then the next in line for examination is the thermostat. (of course check the wiring for loose connections or corrosion if you haven't already done so).
Old Mar 25, 2008 | 06:18 PM
king_kval's Avatar
Default HOT RAPTOR
the thermostat is good.i checked it in hot water with a meat probe.any other sugestions.
Old Mar 25, 2008 | 11:55 PM
recon99's Avatar
Default HOT RAPTOR
How about applying power directly to the fan like I said?
Old Mar 26, 2008 | 02:48 AM
DuneMe's Avatar
Default HOT RAPTOR
<div class="FTQUOTE"><begin quote>Originally posted by: recon99
How about applying power directly to the fan like I said?</end quote></div>
This is the simple way to find out if the fan is working or if it is a thermostat. You should be able to simply by-pass the thermostat and hear it run.
Old Mar 26, 2008 | 04:18 AM
king_kval's Avatar
Default HOT RAPTOR
bought new fan,same thing.it does work direct,but thanks.
........................problem fixed ,there was a short in the wire going to fan cutout relay located under gas tank on left side
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
