AWD not working in reverse
Old Mar 26, 2008 | 12:13 AM
KD5EDP's Avatar
Default AWD not working in reverse
I just bought a 1996 Polaris 300 Explorer. AWD working fine in forward gears. Light goes out when you put it in reverse. Is this normal or do I have a problem? If this is correct anyone ever bypassed it so the AWD works in reverse. Sure is hard to get out of mud in two wheel reverse.
Old Mar 26, 2008 | 02:18 AM
01 SCRAMBLER's Avatar
do you have a reverse override button should be yellow? if so press that while in reverse and see if it works then reply back and let me know if this helped
Old Mar 26, 2008 | 09:54 AM
Ujoint's Avatar
To bypass the reverse need for the override button in AWD:
Find the wires going to/from the AWD switch. The Gray/White stripe wire is the one that comes from the gear position switch. Splice into this Gray/White stripe wire with a source from any Red/White stripe wire (this is power when key switch is turned on).
This will allow for AWD in any gear (as long as the AWD switch is engaged) without having to use the Override button. The Override button still will function for the reverse safety.
Old Mar 26, 2008 | 10:21 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its a common problem who dont know how polaris works to not realize thatthe override button has to be pushed and held for the awd to work.
Old Mar 26, 2008 | 03:12 PM
SCRAMBLER500XXX's Avatar
is the reverse light working when you put it in gear? it could be caused by shifter box switch, switch must work for awd to engage, completeing circuit
Old Mar 26, 2008 | 09:49 PM
KD5EDP's Avatar
It works, my atv is on the trailer so I just turned the key on, put it in reverse and when I pressed the override the AWD came on. Thanks By the way, last weekend I sunk it. If I had know about the reverse I might have saved myself a lot of work and money. Polaris is good but will not run on water.
Old Mar 26, 2008 | 09:53 PM
JCDEYO25's Avatar
Sometimes it pays to read the owner's manual....You learn things that can help you when you get in situations like that...I even carry mine with me....
John
Old Mar 26, 2008 | 10:14 PM
KD5EDP's Avatar
I purchased it used, no owners manual. Thanks anyway
Old Mar 26, 2008 | 11:20 PM
JCDEYO25's Avatar
KD5EDP...
I hope you didn't take that the wrong way....I wasn't trying to say that in a rude way...It's just that there's alot of good info in the manual...Is there anyway you can get a hold of one?
John
Old Mar 27, 2008 | 12:22 PM
OIown12's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: KD5EDP
I purchased it used, no owners manual. Thanks anyway</end quote></div>
If you register on the Polaris web site, you have access to the owner's manual free of charge. You really should take a look at it.
Reactant
Mar 30, 2022 02:08 AM
hugemoth
Jul 20, 2020 03:28 AM
Scottma518
Jul 10, 2015 12:42 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
