Does anybody have an 00-01 ds AND an 04+ ds? I need something checked
Old Mar 27, 2008 | 12:59 PM
R00ST's Avatar
Default Does anybody have an 00-01 ds AND an 04+ ds? I need something checked
I know a few members in here have newer quads (04+) and an oldie but a goodie floating around (00-01). Of those of you out there (or anybody who happens to know..) can someone check to see if an 04+ rear wheel hub will fit on an 00-01 axle?
I have tried searching and nobody seems to know (some said it dosnt). I know there are a couple different hubs floating around (an aluminum that does fit the 00-01, and a different aluminum that came stock on the 04+)
If someone could confirm this for me either way that would be mega-helpful!
Thanks guys
Old Mar 27, 2008 | 11:37 PM
cynick's Avatar
I'm pretty sure they will fit, I don't think they changed the splines for the hubs.
Old Mar 28, 2008 | 12:32 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
I belive that is correct i do know one is thinner then the other the 01's i belive are a tad thinner if you wish to put 01's on an 04 spacers are required but 04's will go right to the 01's with no mods.something to that effect.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 28, 2008 | 01:38 AM
Entomber's Avatar
One thing to consider, I believe I read the 04's and up the studs are pressed in. Earlier models are tapped and threaded. Easily replaced in the event one breaks.
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
