Outlander 800 sunk
Old Mar 27, 2008 | 01:50 AM
rhonda350's Avatar
Default Outlander 800 sunk
yea im pissed 7ft of water dident know it was going to be that deep.
Old Mar 27, 2008 | 09:33 AM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
DAMN 7ft......how'd you get it out??
Old Mar 27, 2008 | 12:11 PM
Sport400inOH's Avatar
Drain everything (assuming you have pulled it out). Any compartment or box (Even electrical components) that can be opened should be opened and left open to air out in a heated space. Replace the air filter. Change ALL fluids (gas & coolant, too) and remove the spark plugs, crank it over a few times (after putting fresh oil in it, but leaving the plugs out). Insert the plugs and give it a shot. If it does run, let it run for several minutes to get warmed up, drive it around lightly and then change the oil again.
If it doesn't run or even crank, charge the battery (If it will take a charge) & check any fuses first. Water can short circuit a battery.
If all else fails, I hope you have good insurance.
Old Mar 27, 2008 | 01:01 PM
rhonda350's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: DS650powe
DAMN 7ft......how'd you get it out??</end quote></div>
well some dude on a boat saw me and he got a rope tied it to the atv and he pulled me to shore.
Old Mar 27, 2008 | 08:28 PM
OhioRenagade's Avatar
Holy cow!,, man thats crazy,, does it run?
Old Mar 28, 2008 | 01:04 AM
rhonda350's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: OhioRenagade
Holy cow!,, man thats crazy,, does it run?</end quote></div>
no not yet im still in the proces of draining and cleaning out the whole moter. its going to take me a while cuz im use to cleaning out a hondas moter cuz i sunk my rancher like 6 times already Rincon 2 times Foreman 3 times Rubicon 1 time almost sunk the rancher 420.
Old Mar 28, 2008 | 01:20 PM
<div class="FTQUOTE"><begin quote>Originally posted by: rhonda350
...i sunk my rancher like 6 times already Rincon 2 times Foreman 3 times Rubicon 1 time almost sunk the rancher 420.</end quote></div>
It occured to me that maybe it is time to invest in a good set of chest waders and test the depth of the water before you try to cross it. You could sure save yourself some time and effort!
bigred20653
Oct 2, 2015 10:05 AM
panicmanic
Sep 28, 2015 12:59 PM
bigred20653
Sep 19, 2015 02:11 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Gtsordo
Jul 22, 2015 01:27 PM
