additional lights
Old Mar 30, 2008 | 01:08 AM
Hawkman300's Avatar
Default additional lights
i have an '06 hawkeye 300 and want more lights on mine. how do i wire them up? to i just cut the wires going from the mounted lights and wire it up, or is it more complex than that? also, can i get more powerful light bulbs for my hawkeye?
Old Mar 30, 2008 | 11:33 AM
02huntinquad's Avatar
i put a driving light kit on my s-man, there are two 55 watt lights adn all the wiring and a swithch. the two 55 wat lights are great for seeng the trail @ night and the don't put to much draw on the battery.
Old Mar 30, 2008 | 02:49 PM
Hawkman300's Avatar
well, could i just buy some lights from wal mart and wire the lights up in the same circuit as the built in lights?
Old Mar 30, 2008 | 03:04 PM
miniexcavator's Avatar
really don't know the output capabilities of the hawkeye but to put it on the same circuit as the existing would not be a good idea because you don't know if the switch and wiring is capable and you would always have all the lights going. I would reccomend additional wiring and switch like huntinquad did imo.
Old Mar 30, 2008 | 03:37 PM
Hawkman300's Avatar
well, i dont have the money to burn $40 on wires and mounts. is this something that i could get some wires and switches from radioshack and do it myself?
Old Mar 30, 2008 | 04:01 PM
onesavage's Avatar
i wired up 2 - 55 watt driveing lights and if i have my lights on and turn them the batt light will start flashing on my pod..but then again my batt is 3 years old..
Old Mar 30, 2008 | 04:56 PM
you pretty much have to buy a quad batery every year, they just dont last, especially if the quad is stored outside!
Old Mar 30, 2008 | 07:11 PM
nickatnite's Avatar
so where did you install the light kit. i want to do it and was wondering a good local.
thanks
Old Mar 30, 2008 | 08:26 PM
i made a roll bar and basket that attaches to the front rack and i welded a couple of tabs on it for the lights and a couple more for an additional rifle holder.
Old Mar 30, 2008 | 09:52 PM
Hawkman300's Avatar
well, would i be able to wire up an additional battery for some additional lights? what i was thinking so that i can use one or the other set of lights or both at the same time is put another battery inside one of the front storage boxes and just use a simple positive and negative wire setup between 2 lights and put the wires through the drainage hole in the storage compartment. i have one of those "motorcycle batteries" that is like the stock battery but is rectangular and just has a + and - rods on the same end. it is 12V. will this work?
