additional lights
Old Mar 30, 2008 | 11:45 PM
02huntinquad's Avatar
Default additional lights
well after the last battery that crapped out on me last fall, i went down to the parts store an got a lawn tractor battery and ran pos and neg battery cables into the quad box where i put the new battery and holder then attached the new cables to the existing connections where the stock cables connected to, and i did away wih the old quad battery, the light are brighter, the winches don't run down, and the starter spins over faster. it's been working really well ever since i did it and i tested the charging output and it's almost 14 volts, so it should work!
Old Mar 30, 2008 | 11:52 PM
Hawkman300's Avatar
well, do you have any pics or vids of your lights? and would what i said work?
Old Mar 31, 2008 | 09:51 PM
as long as you don' go with a too high of wattage of lights, just the one battery should work! the only reason i went with the bigger battery is that i was fed up with those crappy qua batteries that only seemed o last a year! and i'm not too sure on how to get pics on the forum! but i have to take more pics whe i get my snorkel and tires put on!!
Old Apr 1, 2008 | 12:02 AM
RticKwad's Avatar
Runs Stealth!
I wanted to know to, if you put bigger bulbs in the rear lights would that
draw too much on the battery?
R'
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
Steeldon
Sep 9, 2015 09:38 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
