250 r no spark
Old Mar 31, 2008 | 05:39 PM
buckw3's Avatar
Default 250 r no spark
i have an 87 trx 250r i pulled out of storage and went to start it and i'm not getting any spark. Found the wires from the ignition switch broke. i put them back together but am still getting no spark.
any ideas would be greatly appreciated. It was just over a year since the last time it ran but it ran good then
Old Mar 31, 2008 | 11:12 PM
Double t's Avatar
this might be a stupid question to ask but are you grounding the plug while you are kicking it over? Only asking because i watched my friend do it on his 250R. Hopefully it is that easy. if not good luck.
Old Apr 1, 2008 | 10:54 AM
buckw3's Avatar
was holding the plug right to the cylinder head. ran through all the ohm readings and it all checks out right. sounds like the cdi is bad but i cant believe it would go bad out of the blue. it ran great the last time i ran it
Old Apr 1, 2008 | 03:32 PM
HondaMechanic's Avatar
Old Apr 1, 2008 | 07:32 PM
snorulz's Avatar
my cdi box crapped out on my 250r randomly. That would be my guess as to your problem.
Old Apr 1, 2008 | 11:08 PM
Double t's Avatar
try tapping on it with a screwdriver handle. mine is starting to go bad. died a couple times last weekend. beat on the cdi fired right up. if you can tap on it and get it to spark a little, it might conferm your diagnosis.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
