dash lights
Old Apr 2, 2008 | 04:52 PM
mountainclimber's Avatar
Default dash lights
I have a 2003 400 Manual ACT when riding today i was in neutral and the neutral and reverse light were on at the same time. The revese light was the only one on when i reverse but when shifting back into neutral both lights wer eon again and no lights were on in any forward gear. When the reverse light is on with the neutral light is to the reverse light flickers at idle and stays bright and solid when the engine was revved... any ideas of what this is or how to fix it? thanks
Old Apr 4, 2008 | 02:29 AM
Bobmack's Avatar
Default dash lights
there a switch under the fender by your revese lever, it is not adjusted right or its bad
Old Apr 4, 2008 | 10:59 AM
Default dash lights
how would you adjust it? or if i put it in low gear and it still says R is it just bad?
Old Apr 5, 2008 | 03:36 AM
Bobmack's Avatar
Default dash lights
its just a button switch then you shift in revese the leveler pushes in on the button turns the light on, maybe its just stuck in or bad . this might help http://www.alpha-sports.com/arctic_cat_atv_parts.htm go to 2003 and then go to 03 400 fis manual and then revese shift lever assemble this will show you a picture i hope this help. that switch is 28.50
vandammages@gmail.com
Aug 20, 2020 11:50 AM
salixair
Nov 3, 2015 08:25 AM
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
