no awd 2003 polaris
Old Apr 2, 2008 | 05:57 PM
neohio's Avatar
Default no awd 2003 polaris
My bike was wrecked and the speedometer and dash lights do not work at all. Also, my AWD does not work. Is there a way to fix this problem without spending a lot of money to replace everything. I do not care if the speedometer and lights work, I just want my AWD to work again. Is there a way to hot wire or does anyone have/know which wires do what? Thanks!
Old Apr 3, 2008 | 08:38 PM
Spman 800's Avatar
cheak with your dealer i think you might be able to buy a new all wheel drive swich and ifx th prob
Old Apr 3, 2008 | 08:56 PM
DODGE57HEMI's Avatar
Mopar Man!
I had the same problem after a wreck on my 04 600 after tracing some wires for the speedo under front hood found a ground wire to speedo that had became broke from the impact reconnected to the ground [frame] both the speedo and awd switch work fine. Hope this helps.
Old Apr 3, 2008 | 09:56 PM
tux's Avatar
tux
also a quick check to do is if your speedo is not working ckeck to see if the speedo cabel ends are tight on the tranny and speedo. i have heard for some strange reason they work together. not 100% sure of this but worth a try.
tux
Jmuddin284
Jan 19, 2026 07:16 AM
slowgsxr97
Mar 18, 2022 03:40 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
95wolv
Jul 17, 2015 08:13 PM
