dinli 90
Old Apr 2, 2008 | 10:54 PM
scooter0946's Avatar
Default dinli 90
i have a dinli 90 does anybody know how or if i can run alchol fuel??? i have a hetricks b 52 kit and a stroker kit in it and i asked hetrick but they have never tryed it.we just run 300 feet at the dirt drags .
Old Apr 3, 2008 | 01:42 AM
hotblooded's Avatar
Default dinli 90
I haven't really heard of someone running methanol in a quad. I ran methanol in my competition truck, I do know that it does require a special carb for methanol. You can figure going through twice as much methanol than fuel and that is why it requires a different carb. It is to allow more fuel flow. You also have to be concerned about the compression ratio. Methanol will not be productive in a motor that has 14:1 or higher compression. The reason Methanol makes more power is that it burns slow and cold. It expands throughout more of the stroke and not just a flash, hence is high octane fuel. Octane is a retardent which is added to prevent pre ignition which would be detrimental to a high performance motor. If you do get it to work you will have to start the motor on gas. Typically a methanol motor will not start cold on just methanol, you have to inject gas to start it until it is warm.
If you get this to work let me know.
Old Apr 3, 2008 | 12:30 PM
Default dinli 90
thanks for the coment maybe it just wont work i dont know
Ashley S
Feb 18, 2024 08:56 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Fizzy
Mar 19, 2011 08:10 AM
oldsandman
KTM
11
Jan 21, 2004 01:31 PM
Harw
KTM
14
Dec 19, 2003 09:08 AM
