front ADC diff
Old Apr 3, 2008 | 02:22 PM
RickCJ7's Avatar
Default front ADC diff
I just got my ADC front diff today after waiting like 3 weeks.
Can't complain too much since it was FREE.
Looks like a project for next week.
Old Apr 3, 2008 | 02:42 PM
GunnSmoke's Avatar
rick how did you score that deal?? i noticed on the PA site a guy with your same handle selling a scrambler would you be that same dude??
Old Apr 3, 2008 | 08:34 PM
ned_28's Avatar
are polaris having trouble with these, i have an o8 sportsman 500, is that something i gotta worry about
Old Apr 3, 2008 | 08:39 PM
RickCJ7's Avatar
My diff is leaking ADC fluid internally, I fill it up and a couple days later it's in the LT fluid.
Hilliard wants it back to see whats wrong, said it's the 1st one to have this problem.
Other than someone filling the diff with the wrong gear lube not any common problems.
Old Apr 3, 2008 | 10:11 PM
ned_28's Avatar
thats good, for the fun of it i looked that whole assembly up on bike bandit, its like eight hundred and some odd dollars for that, so u gotta good deal
Old Apr 3, 2008 | 10:37 PM
sheepdogMSP8117's Avatar
Good luck with the install.
Old Apr 3, 2008 | 10:57 PM
SCRAMMYTODD's Avatar
It's pretty easy to do. Unplug wiring and hoses, remove driveshaft, pull one ball joint, pull axle on that side, unbolt diff remove other axle and slide diff out. Should be out in about 15 minutes if you hurry.
Old Apr 4, 2008 | 11:12 PM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: SCRAMMYTODD
It's pretty easy to do. Unplug wiring and hoses, remove driveshaft, pull one ball joint, pull axle on that side, unbolt diff remove other axle and slide diff out. Should be out in about 15 minutes if you hurry.</end quote></div>
Wish I could've got it done that quick! Took 2 hrs., had a hard time getting the axles out and had to pull the front bumper and remove the diff out the front.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
Sportsman850
Jul 31, 2015 04:25 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
