hawkeye 300 4x4
Old Apr 3, 2008 | 09:07 PM
northgang's Avatar
Default hawkeye 300 4x4
Hi, I just bought a used hawkeye 300 4x4 with no manual. Does anyone know the oil capacity with filter? thanks
Old Apr 3, 2008 | 09:18 PM
TennesseeTider's Avatar
Manual says 2 quarts, but i'd start with a little over 1.5 quarts. Mine usually takes about 1.75 quarts to be at the full mark. 2 quarts and mine will be too full.
Old Apr 3, 2008 | 09:20 PM
northgang's Avatar
thanks, mine is a 2007, do you think it would be different?
Old Apr 3, 2008 | 09:24 PM
It should be the same unless yours has the optinal auxillary oil cooler (looks like a small radiator). The Polaris Service manual actually says 1.4-1.7 quarts per oil/filter change without the oil cooler.
Old Apr 3, 2008 | 09:28 PM
northgang's Avatar
thanks again, got one more question. there is an angled plug on the right side of the oil pan, is it another drain plug, maybe for an additional oil chamber?
Old Apr 3, 2008 | 09:31 PM
I dont think so. There is just one drain bolt.
Old Apr 5, 2008 | 07:22 PM
maddog24's Avatar
Hey Northgang,
I have a 2007 Haweye and i have changed (Oil & Filter) 2-times on mine and it has taken 2-quarts and its not over the Fill Mark !!
Maddog24
Old Apr 6, 2008 | 11:16 AM
jokout's Avatar
Northgang, you may want to go to the Polaris site and download a owners manual for your bike...you will have to register your e-mail addy but no biggy. Heres the link
http://www.polarisindustries.c...F%7d&NRCACHEHINT=Guest
Old Apr 6, 2008 | 02:58 PM
Mongrol's Avatar
"Official Site Skeptic"
Real Important.
If you change your own oil, make sure you use a 6mm allen wrench in the drain plug. IT IS METRIC. If you use a SAE (american) wrench, you will probably strip the bolt.
snowolson
Aug 31, 2015 03:51 PM
Sportsman850
Jul 31, 2015 04:25 PM
GreenHawkeye
Jan 1, 2006 07:16 PM
DAHUI
Dec 17, 2005 06:49 PM
