lt 80 carb
Old Apr 4, 2008 | 05:58 PM
sp01's Avatar
Default lt 80 carb
what size of carb should i run on a 105 kit with a full race port
Old Apr 4, 2008 | 08:37 PM
onebigzj's Avatar
Default lt 80 carb
first of all why would you make it a 105? I would have the stock one worked. I just got mine close to perfect. runs right with a cr80. befor you go with a big bore that is not as reliable. get ahold of jack ( lt80) and get redy to hold on
Old Apr 4, 2008 | 10:40 PM
sp01's Avatar
Default lt 80 carb
I bought it with the 105 kit in it im on my last over bore and i have a stock cyl ready to get work done im just worred about the lower end porting that I have had done to it I was also told that if i got away from the 105 kit that I could never get the same power.
Old Apr 4, 2008 | 10:49 PM
onebigzj's Avatar
Default lt 80 carb
did they give HP numbers? a jack moore motor has 11hp at 11,000 rpm with stock pipe and if you add the trinnity pipe its hp numbers go to 15hp at 12,000 rpm. lt80 will chime in with some other info on this topic.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
