Jetting?
Old Apr 5, 2008 | 12:52 AM
wutsupy's Avatar
Default Jetting?
i have a yamaha blaster, just rebuilt has a wesco piston bored.20 over, toomey full pipe the jetting toomey gave me and the air filter also has no air box i am getting power now and a kn air filter with a out fitters exhaust, i was told the jetting needs to be changed
I need input for jetting
Old Apr 5, 2008 | 02:17 PM
Terrellster's Avatar
Default Jetting?
I'd recommend a very small size change with the set-up, but definitely go a bit larger to increase fuel to air ratio. Running lean will cause damage pretty quick. It will run hot due to the lean mixture, and will not cool well.
I would recommend taking a look at Toomey's website and seeing if they can help with best jetting.
I did some looking and FMF recommends a 260 for original piston/bore and their rig, I bet you'd need to go up a bit from there. Also it depends on several things to get optimum jetting. Including Altitude, Average Temp, Humidity, and fuel type and mix ratio.
Good luck
Old Apr 5, 2008 | 06:21 PM
wutsupy's Avatar
Default Jetting?
i live in wisconsin and i drive all year round does it matter to change jetting trough out the seasons or does it matter? can some one tell me a pecific size i need to use in my machine.
Yamaha Blaster
Toomey Pipe
K&K filter
Outfiters Prefilter
reeds
Wesco Piston .20 over
no filter lid
Removed the oil injector
Buying reed spacer
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
