Drilling carb slide
I am going to do the carb slide drill mod went i recive my DynoJet Ket, but looking at the Carb slide on the Parts Diagram it looks like there are 3-holes. I known the Center one is for the spring but i need to known if i am to drill out both of the other two holes (and i under stand that most every one is using a 1/8" Drill Bit to do this) Thanks for any Feed Back.
Maddog24 (Jeff)
Maddog24 (Jeff)
Jeff, you are looking at the top of the slide. Do not drill there. You will drill the bottom of the slide. I do not remember the size of the hole I drilled, I just made another hole equal to the size of the hole that was already there. I drilled the new hole on the oppsoite side of the slide from the existing hole.
