Drilling carb slide
Old Apr 5, 2008 | 04:00 PM
maddog24's Avatar
Default Drilling carb slide
I am going to do the carb slide drill mod went i recive my DynoJet Ket, but looking at the Carb slide on the Parts Diagram it looks like there are 3-holes. I known the Center one is for the spring but i need to known if i am to drill out both of the other two holes (and i under stand that most every one is using a 1/8" Drill Bit to do this) Thanks for any Feed Back.
Maddog24 (Jeff)
Old Apr 5, 2008 | 08:12 PM
TennesseeTider's Avatar
Jeff, you are looking at the top of the slide. Do not drill there. You will drill the bottom of the slide. I do not remember the size of the hole I drilled, I just made another hole equal to the size of the hole that was already there. I drilled the new hole on the oppsoite side of the slide from the existing hole.
Old Apr 5, 2008 | 10:40 PM
maddog24's Avatar
TennesseeTider,
Thanks for the feed back that will help me alot when i get to do this mod!! Thanks again.
slowgsxr97
Mar 18, 2022 03:40 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 15, 2015 10:48 PM
