warrior axle housing
Old Apr 5, 2008 | 11:05 PM
87 warrior's Avatar
Default warrior axle housing
i ordered a axle housing off ebay from a 98 warrior to replace it with my 87 warrior. i put it on and the brake rotor goes all the way against the mounting braket......?
could this be brake disc hub? is a 98 that much different from a 87? i was thinking maybe the 98 hub is a little bit longer than the 87...... or are the axles a different length?
Old Apr 5, 2008 | 11:49 PM
Patches3489's Avatar
you should post a picture of what you are talking about.
Old Apr 6, 2008 | 01:28 PM
Raptor450's Avatar
The axle housing is different, as well as the swingarm. The first Warriors had the axle carrier bolts threaded directly into the swingarm, where the '90-up had bolts and nuts to hold it on. This was always a problem because the axle carrier bolts always stripped out the threads on the swingarm. I'm not sure of any more differences.
Old Apr 6, 2008 | 02:01 PM
87 warrior's Avatar
ok, i also noticed that the 87 brake rotor is smaller than the 90-up. why is that?
also i just replaced the throttle cable and the new one seems to be an 8th of an inch too short. i have it routed through the frame right and the adjusters are all the way in. am i overlooking something? the picture in the book shows the same problem but doesn't say how to fix it...... do you have any ideas?
Old Apr 7, 2008 | 01:37 AM
when i routed my cable i had it running through the frame correctly but right under the handle bars there is a little piece of metal like a bracket for something the my cable was caught on. i noticed it pretty easily so i don't really see you looking over it, just check and make sure, you never know. by-the-way i tried to use an older banshee rotor for my 2001 warrior it had the same bolt pattern but it was about a 1/2 inch smaller in radius than my stock rotor. sorry if i couldn't help much.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
1000gade
Sep 9, 2015 04:41 PM
