cherry red exhaust
Old Apr 8, 2008 | 03:37 PM
rigor mortis's Avatar
Default cherry red exhaust
brother is letting me use his 01 trx350fm 4x4 rancher,it sat a couple of years,hard to crank got it running,couple days later noticed fuel running out of bowl and the exhaust out of the head was cherry red,tapped on the bowl to try and unstick the float,still leaks.is the needle stuck,should i rebuild the carb?also someone told be the timing could be off.any suggestions would be great
Old Apr 8, 2008 | 03:58 PM
jrafter's Avatar
yes i would clean up the carb it sounds like it was running lean and you can melt the piston like that
Old Apr 8, 2008 | 04:39 PM
my thoughts on the piston also,turned it off as soon as i saw the red,guess ill be rebuilding the carb
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
