bashan 200 s-7 atv slight problem
hi guys
Im also new to this game in the atv world but looking for some help.As im doing around 45 mph then back off the rear seems to snake a bit which puts the ******* up me a little have only been out on the quad half of dozen times and love it im also a big fellow around 17 stone so do you know what the tyre pressure should be also what do you make of the tyres they come with please help regards shaun
Rear tires should be at around 7psi
Front can be a bit more, but I run 7psi all around. This will vary with each rider though. These things come with full pressure, because they need 20psi to pop the bead. They dont let any out after that. You will have to get a gauge that reads lower than 10-psi to get an accurate reading. Discount sells them for 4.95
Check the alignment of the chain. It could be turned a bit to one side too much. Also, go over the frame, and make sure theres no bends.
If its just kicking to the side after you let off the gas, it could be a number of things, but I would check the chain first. See if the tensioners
are even.
are even.
bpegram84
Jul 22, 2015 08:15 AM
