bashan 200 s-7 atv slight problem
Old Apr 8, 2008 | 05:35 PM
dahotstepper's Avatar
Default bashan 200 s-7 atv slight problem
hi guys
Im also new to this game in the atv world but looking for some help.As im doing around 45 mph then back off the rear seems to snake a bit which puts the ******* up me a little have only been out on the quad half of dozen times and love it im also a big fellow around 17 stone so do you know what the tyre pressure should be also what do you make of the tyres they come with please help regards shaun
Old Apr 8, 2008 | 06:33 PM
sflarider's Avatar
Rear tires should be at around 7psi
Front can be a bit more, but I run 7psi all around. This will vary with each rider though. These things come with full pressure, because they need 20psi to pop the bead. They dont let any out after that. You will have to get a gauge that reads lower than 10-psi to get an accurate reading. Discount sells them for 4.95
Old Apr 9, 2008 | 04:51 AM
hi mate thanks for that i have put 10 in the rear and 8 in the front any idear what the snaking is all about ?
Old Apr 9, 2008 | 01:55 PM
sflarider's Avatar
Check the alignment of the chain. It could be turned a bit to one side too much. Also, go over the frame, and make sure theres no bends.
If its just kicking to the side after you let off the gas, it could be a number of things, but I would check the chain first. See if the tensioners
are even.
Old Apr 9, 2008 | 02:06 PM
89stp's Avatar
It could be a loose bolt on the swing arm.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
hondarider1234
Jul 21, 2015 11:53 PM
D-Hagz
Jul 4, 2015 02:19 AM
