blaster stuck in nutral
Old Apr 9, 2008 | 03:37 AM
duneracing537's Avatar
Default blaster stuck in nutral
I have this blaster that starts great but it is stuck in nutral. It will shift gears but wont come out of nutral. I tore it down thinking it might be a shift fork. They seem fine to me. not bent. All my gears look good. I am stumped.
Old Apr 10, 2008 | 11:10 AM
270quadsportguy's Avatar
check to see if the ball between the clutch rods is welded together. U will have to pull the side cover, put in gear and push it if the center hub spins and the motor dont u either have bad clutches or the ball that is between the rods that go thru the center shaft of clutch is welded together. I had to fix a blaster with the welded ball and had to change the counter shaft in tranny
Jeff Roper
Feb 1, 2022 11:48 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Jackg17
Sep 26, 2015 09:30 PM
