yamaha wolverine problem
Old Apr 11, 2008 | 05:02 PM
timberwolf3535's Avatar
Default yamaha wolverine problem
i got a 96 yamaha wolverine i think is a 96 and last time i went rideing i started to smell gas when i stoped and looked it was leaking i the fuel line on the bottom of the carb was disconnected on the other end so it still conected to the bottom of the carb but on the other end it has a plastic almost like fitting joint on it were does it go thanks alot
Old Apr 11, 2008 | 10:33 PM
yotatrailrunner's Avatar
Sounds like the fuel bowl drain. check to see were it goes into the fuel bowl and see if there is a screw near it. if so screw it in and it should stop leaking.
Old Apr 13, 2008 | 11:34 AM
thanks alot it was a fuel drain line and it was a valve at the end but cleaned it out and works great
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
