05 raptor 350 suspension setup advice please
Old Apr 13, 2008 | 09:02 PM
cmcge712's Avatar
Default 05 raptor 350 suspension setup advice please
i have a yamaha 2005 raptor 350. i have a good amount of money dumped into it.
i need to know how to set my front and rear suspension and what should i set it to? please help i am 6'1 190pds
Old Apr 14, 2008 | 11:18 AM
yotatrailrunner's Avatar
on a stock raptor 350 all you can adjust is ride height. get some elka's and you can adjust preload (ride height) compression and rebound depending on which options you get. I put some 05 YFZ450 shocks on my wifes 350 and she loves them they have rebound and compression adjustments and they are sprung lighter than the factory shocks so it is alot better for her when we race Cross Country.
Old Apr 14, 2008 | 04:50 PM
cmcge712's Avatar
so wait u put yfz450 shocks on a raptor 350. front and rear??? wow that cool. how much did it cost and how hard was it? how do can i adjust the ride height on my raptor?
Old Apr 14, 2008 | 05:55 PM
just on the front. the rear is still stock but a 2001 raptor 660 rear shock is a nice upgrade for the rear. to adjust the ride height with your stock shocks you need to turn the chrome piece under the spring to the right to raise the ride height or to the left to lower it.
Old Apr 14, 2008 | 08:03 PM
cmcge712's Avatar
thnks again man. i am sorry but i have another question. do you have any suggestions on what i should set it to? i am 6 foot 1 190pds. also can u adjust just the rear or just the front or both? thnks again yotatrailrunner
Old Apr 15, 2008 | 12:16 AM
when setting the ride height it takes 2 people. You need to sit on the bike in your riding positon. you then have some one measure the ground clearance under the front engine mount and under the swing arm mount. the front needs to be about 1/4 - 1/2" higher than the rear. stock that is all you can adjust. if you swap in YFZ450 shocks you can adjust the rebound and compression. when setting the rebound you want the shock to extend fast enough to take the next hit with out shoving the handle bars back into your hands but not to slow that the shock is still compressed when you take the next hit.. when setting the compression you want the shock to give just enough so it absorbs the bump but that the front end does not dive when you hit the brakes.
Old Apr 15, 2008 | 01:59 PM
cmcge712's Avatar
hey thnks for the advice
black_thunder
Sep 6, 2015 04:41 PM
toonces
Sep 5, 2015 01:14 PM
Erick J. Edler
Aug 26, 2015 01:51 PM
Mssarabug
Aug 10, 2015 12:56 PM
GNorm
Aug 1, 2015 11:06 AM
