250x timing question
Old Apr 15, 2008 | 07:59 PM
roots250x's Avatar
Default 250x timing question
Hello .First time posting. I have been reading the forum for awhile and came up with a problem I couldnt find an answer to.heres the story........ My quad started smoking real bad .I had changed piston and jug ,when timed the first time it tapped real hard. I brought it home and hadnt gotten around to doing anything else to it. well now weather is getting better I went out to check the timing (have read most of the post about it) My probluem is when I look in the small hole I cant find anything to line up. I know I had turned the flywheel many rotations but no mark was found.
Old May 1, 2008 | 12:40 AM
trenth48's Avatar
it's hard to see, its best if you get a drop light or flash light and shine in the hole and slowly rotate the crank. it should be on the round surface of the crank the best i remember.
awheelterd
Feb 2, 2021 06:18 PM
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
D-Hagz
Jul 4, 2015 02:19 AM
big_g_squared
Jun 28, 2015 04:17 PM
