foot brake issues
Old Apr 16, 2008 | 07:19 PM
irishdreamsnd's Avatar
Default foot brake issues
my 4 wheeler has been sitting up for a couple of years because of a broken shift plate .I have just fixed it and i am finding many more problems. The brake at your foot is stuck you can not pull it up or down can anyone lead me in the right direction to fix this.
Old Apr 17, 2008 | 10:04 AM
Androctus's Avatar
cable could have rusted and seized. You might free it with some penetrating oil, but if it has rusted badly it eventually will fail. Probably good idea to replace it.
Old Apr 17, 2008 | 12:57 PM
mopar_man's Avatar
The one on the Recon I just bought had the same problem. The lever is rusted to the frame. I'm not sure how yours is attached but I had a cotter pin holding mine on and I had to use a pulley puller (you can rent one from most automotive supply stores if you don't have one). I would try putting some penetrating oil on it and see if that frees it up or not.
Old Apr 17, 2008 | 10:42 PM
action450s's Avatar
I had my foot brake get stiff, I took it apart, the cable was fine, but the lever was stuck on the frame. I removed the cotter pin and washer, pulled and cursed the lever off, cleaned and lubed the pivot point and now its good as new.
Old Apr 18, 2008 | 12:28 AM
thanks for the help im going to pull it apart but one question was you able to pull it off by hand are did you have to have a pulley puller like moparman said
Old Apr 20, 2008 | 12:15 PM
Got the foot brake loose from the frame(not an easy job to do)and cleaned it,greased it and put it back together and now its like its brand new thanks everybody
DeFox500
Jul 26, 2015 06:32 PM
timster911
Jul 13, 2015 01:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Armyguy1
Utility ATVs
Jul 6, 2015 12:42 AM
