The Truth on Air Filters Please.
Old Jan 21, 2000 | 04:20 PM
bshiels's Avatar
I am currently running a K&N without prefilter on my 400ex. Some of the posts I have read here lately have raised some questions:
If the K&N is cleaned, oiled and installed as directed, will it pass small particles of dirt without the prefilter?
How about with the prefilter?
Does the Uni filter or Pro flow do a better job of filtering than the K&N?
How do these two compare to the K&N when it comes to restricting the airflow?
I do have a powercore IV and jet kit so I do want more airflow than I had with the stock foam filter.
Thanks for the comments..
Old Jan 21, 2000 | 05:45 PM
Rocky's Avatar
you hear alot of good and bad about both styles K&N and foam. I used to run a K&N but now changed to a foam pro flow. I do believe the foam filter does a better job but the K&N should be fine I would definately have an outerweares on it though.
Old Jan 21, 2000 | 07:57 PM
Johnnnn__H's Avatar
A K&N will outflow a foam filter, and a K&N is better for stopping sand. A foam filter is better for stopping verry fine
dust, you know that %$#$&& cloud of dust you drive through when you follow someone. But foam are not recomended for sand.
>>>>>>>>>>>>>>>>BUT<<<<<<<<<<<<<<<<<<<<<<<<
Changing your oil removes crud that passed through your filter, K&N, or foam. That is whare the dirt ends up, in your oil. Not to mention fresh oil is a good thing!
Old Jan 25, 2000 | 06:40 PM
sik_banshee's Avatar
I found that a Pro-Flow foam filter with an outerwear works great in the sand. Nothing gets through.
Old Jan 26, 2000 | 05:39 PM
atvervic's Avatar
I read that somebody but some panty hose on it{K&N) and it doesn't restrict airflow.
[This message has been edited by atvervic (edited 01-26-2000).]
Old Jan 27, 2000 | 09:42 PM
sombre's Avatar
The only problem I've had with the K&N is that because it traps dirt on the surface it tends to plug up real quick...Never had anything get by with it as long as it's on tight.
As far as I can tell the prefilter is just to help keep the big particles off the filter it doesn't catch smaller particles.
Greg
'98 banshee
Ridgebackguy86
Sep 19, 2015 12:48 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Pahuntman
Sep 5, 2015 11:07 AM
