Correct pre- mix ratio using Polaris two stroke oil?
Old Apr 20, 2008 | 12:18 AM
Jlutty444's Avatar
Default Correct pre- mix ratio using Polaris two stroke oil?
Hello-
I just bought a 2000 Xplorer 400 4x4.
The injector is blocked off.
The previous owner ran BEAN OIL in the gas at a 32 to 1 ratio.
What should I mix the gas with and at what ratio to make this run right and live a long time?
It has 800 miles on it now.
I already bought the Polaris oil to mix and has no ratio on the bottle.
Any advice?
Old Apr 20, 2008 | 09:26 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would stick to the 32 to 1 mix
Old Apr 20, 2008 | 09:28 AM
bullpark1956's Avatar
the actual ratio is 40 to 1 16oz to 5 gal gas
Old Apr 20, 2008 | 10:05 AM
QWODER's Avatar
32:1 or 40:1 will be fine.32:1 is safer.
Old Apr 20, 2008 | 10:24 AM
Rowe's Avatar
I would stick with the polaris oil my buddy ran a couple tanks of that bean oil through his blaster once and fouled a few plugs. I gave him a tank of my gas w/ the Po oil and it never fouled a plug he switched after that I still have the bean oil in my shed.
Old Apr 20, 2008 | 10:49 AM
Jlutty444's Avatar
Thanks alot!
That gives me room. Now, I understand the basic formula and I wonder what the range is on a tank of gas so I can start planning how many gallons to bring to "the farm" on weekends.
Is polaris fuel additive the best for bearings, etc.?
Old Apr 20, 2008 | 12:37 PM
if it was me id only run the polaris oil only no additives maybe once in while a little sea foam in it wont hurt any at all will help keep thing cleaned up and good running order
Old Apr 20, 2008 | 11:40 PM
ftwflh's Avatar
40:1 will make it run like it should 32:1 will work but............
Old Apr 21, 2008 | 10:16 PM
ventron's Avatar
You should run at 40:1 using a good synthetic. Lower ratio is not always better. Can make it run hotter
Old Apr 22, 2008 | 09:30 AM
Jlutty444's Avatar
OK- What os "a good synthetic" that is available anywhere?
Are all two - stroke additives the same?
Why does Klotz come to mind. I love the smell of that stuff.
