Correct pre- mix ratio using Polaris two stroke oil?
I finally got in and adjusted the idle to make it go in gear quieter. I discovered that the mix screw was out 3 turns and the idle was turned way up.
I put the mix screw so it's out 2 turns and turned the idle way down. Now I am changing my pre- mix ratio to 40:1
TLC
Jul 11, 2015 02:28 AM
Jul 7, 2015 11:00 PM
