700 efi backfire
Old Apr 21, 2008 | 06:23 AM
gvance's Avatar
Default 700 efi backfire
Went to start my 2007 700 efi and everything seemed normal until i it wouldnt rev up all the way,and it backfired on wide open throttle.If the battery is low on these efi machines,will this cause them to run rough.Seems i cant keep the battery fully charged.Thanks.
Old May 13, 2008 | 12:53 PM
sassee's Avatar
Did you ever find out if low battery caused back-fire? I'm having similar issues with my AC400. I know the battery is toast. It will crank and idle, but if you try to give it any gas, it spits, sputters, back-fires, etc. Weird thing is, it improves when winch button is depressed or I turn on the headlights!?!?!? I haven't changed the battery yet since i don't want to buy a battery if it still isn't going to run. I will ride the Polaris if necessary
Old May 18, 2008 | 10:34 AM
contentsunderpressur's Avatar
Yes, a low battery on a fuel injected machine can cause it to do that at high rpms.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
