warrior starting problems
Old Apr 21, 2008 | 07:13 AM
671warrior's Avatar
Default warrior starting problems
i have a 1995 warrior pass down. it runs good. has a new battery. when i got it, it used a piece of wire to start it. it was connected to the negitive part of the slinoid or something(someting near the fuses on the rear left side) and i have to rub the other end of the wire on the positive part to start the quad. the start button rearly works. i have checked to see if anything was loose or not connected good but all was normal. is there any other thing i could do or check that could help.
Old Apr 22, 2008 | 10:35 PM
rpeace's Avatar
if you have the arm strength...spend 85 bucks on a pull start or 62 dollars on a new switch...buy new cause you might just waste money on a used one...
Old Apr 22, 2008 | 10:36 PM
rpeace's Avatar
or u should be able to pick up a celinoid for around 30 if thats the problem...
Old Apr 23, 2008 | 11:54 PM
671warrior's Avatar
cool thanks i'll give it a shot........
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
