300 clutch adjustment
Old Apr 22, 2008 | 08:18 AM
mbueker's Avatar
Default 300 clutch adjustment
Not sure how to adjust clutch on this bike I have 98 454 and manual but 300 4x4 is different can someone tell me how?thanks
Old Apr 22, 2008 | 10:31 AM
Ujoint's Avatar
Arctic Cat 250/300 Clutch Adjustment (Arctic Cat 2000 Service Manual) - should be the same for all years 250/300.
To adjust the clutch, use the following procedure.
1. Using an impact driver, remove the cover. Account for the O-ring.
2. Loosen the jam nut securing the adjustment screw.
3. Rotate the adjustment screw clockwise until it stops.
4. Rotate the adjustment screw counterclockwise 1/8 turn; then lock the jam nut securing the adjustment screw.
NOTE: At this point the clutch should be adjusted correctly. Test ride the ATV to ensure accurate adjustment.
5. Secure the cover making sure the O-ring is properly positioned.
Old Apr 22, 2008 | 12:15 PM
mbueker's Avatar
thanks i will try this afternoon looked at part breakdown now i see adjustment screw
ghost civic
Jan 15, 2020 07:43 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
