Grizzly with HMF and bogging problems
Old Apr 27, 2008 | 11:11 AM
Abear's Avatar
Default Grizzly with HMF and bogging problems
Hey guys, new to the forum. Got a Grizzly 660 and just added HMF Swamp Series with K an N filter. Jetted it to 175 main jet. With the air/fuel screw out 2.5 turns and the air box lid on, I hammer the gas it bogs down. If I remove the airbox lid and hammer the throttle, it shoots off like a bat out of hell. I believe it is obviously needing better air flow. Does anyone have any suggestions. Maybe need to change the pilot jet? Thanks
Old Apr 27, 2008 | 11:43 AM
95wolv's Avatar
You basically answered your own question, if more air makes it run fine, you are jetted too rich, or the needle needs to be dropped a notch. Unless you want to run without the lid, which would be safe to do if you added an Outerwears water repellent cover mesh, it would be like a lidless air box, but still keep the mud and water from landing on your filter. Either that, or drop the main a size and see how that works. What was the stock jet size, if I may ask? how many sizes did you jet up for the silencer and K&N ? Information like that will help to isolate the problem, also, did you change the needle clip setting?
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
greg74
Sep 10, 2019 03:03 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
