griz cutting out
Old Apr 28, 2008 | 12:39 AM
goatguy's Avatar
Default griz cutting out
2004 grizzly has always ran perfect and the last few days it started acting like it is hitting the reverse/lock limiter even when it is not even in 4wheel drive or reverse. When it cuts out the reverse light comes on so both the H light and the R light are on. I tried pushing the override button and it did not help. Any ideas?
thanks
Steve
Old Apr 28, 2008 | 11:40 AM
cluby's Avatar
Sounds like a bad revrse switch. should be on top of the motor under the air box/carb just unplug it and see if it goes away, but beware then you will have no revrse limter.
Old Apr 28, 2008 | 02:05 PM
goatguy's Avatar
I tried unhooking the reverse switch. The (R) light stays on then and it cut out worse. Does that need to be grounded to test this problem? I put it in dif lock and that limiter sputters different and the override works for that one.
Old Apr 28, 2008 | 07:49 PM
HooPharted's Avatar
cant remember where i put my owners manual,but i seem to recall that a flashing reverse light is a warning indicator for a specific issue
Old Apr 29, 2008 | 09:11 AM
cluby's Avatar
Ya you need to ground it sorry I forgot to mention that.
Old Apr 29, 2008 | 12:50 PM
goatguy's Avatar
Thanks Cluby, you hit it right on the head. It runs perfect with that wire grounded, I will get a reverse switch on the way.
thanks again
Steve
Old Apr 30, 2008 | 07:40 AM
Hebs's Avatar
The root of the cause is the brass washer on the reverse switch is too thick and doesn't provide good contact. They have a replacement part.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Elkaholic
Sep 6, 2015 02:44 PM
