Warrior Jetting?? With Pipe and Filter Kit
I recently bought a Pro circuit T-4 slip on, and a pro design k&n filter kit and a Dyno Jetkit for my '03 Warrior, I havn't installed any of it yet because I was wondering how I should jet my carb and if any adjustment is needed on the carbs fuel/air mixture screw. Any suggestions????
Thanks
Thanks
With my '03, I just installed an HMF slip-on, K&N filter and Outerwear. I first cleaned the carb, set the jetting to 152 (came from HMF), removed the air box snorkel (as well as drilled a few holes in the airbox lid) and turned the air/fuel screw out 3 turns. This seems good for my set up and should give you a decent starting point.
fordfaithful21
Dec 7, 2015 05:52 PM
