back firing through carbs
Old May 3, 2008 | 06:33 PM
raptorbroke's Avatar
Default back firing through carbs
hey just set my raptor in time after replacing the starter clutch set the vales n stuff putt er all back together n won't start back fires n blows the boot off the carbs, tore it apart bout 20 times and i don;y know what to do from here need some help if neone can
Old May 3, 2008 | 07:38 PM
gfreitag71's Avatar
Im having the same problem with my warrior and have my question posted right below yours! I will be watching for a response.....
Old May 3, 2008 | 11:45 PM
Doctorturbo's Avatar
GOT BOOST!
Two things come to mind.
Check the valves again and/or do a compression check.
And you might be lean for some reason also.
Could be lots of things, but these two would be first on my list.
Could also be spark timing. But I don't know what you took apart.
Old May 4, 2008 | 11:50 PM
ii checked the valves again ni got good compression all i took apart was the left side of the case to put a new starter clutch in put it back together without the woodrithf key on the crank and knocked it out of timing so tore it back apart put the key back in the crank and took the valve cover off to set the timing the only thing is i used an aftermarket starter clutch that was garrunteed not to break for life n im not sure if that has nething to do with it
Old May 5, 2008 | 05:31 PM
oblytr8's Avatar
Your new starter clutch should have nothing to do with the backfiring. All the new starter clutch is doing, is enabling the engine to be turned over. The big mistake was leaving out the woodruff key the first time it was put back together. It still still sounds like the timing is WAY off if it is backfiring through the carbs. It's firing when your exhaust valve is closed, and your intake valve down, so completely backwards.
Old May 5, 2008 | 11:51 PM
ok im following wat the clymer book says so ill do it again thanks for the imput
buckshit
Sep 24, 2015 08:49 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Steven Bandemer
May 27, 2015 07:39 PM
