Oil leak in 110 atv
Old May 7, 2008 | 05:56 PM
cheappurchase's Avatar
Default Oil leak in 110 atv
Noticed an oil leak on my daughter's 1.5 year old 110. Oil leak is shown in the picture. Any advice would be appreciated.
-ryanpicture of oil leak here
Old May 7, 2008 | 07:26 PM
chineseatvmechanic's Avatar
from what i see in the picture looks to be a crack in the case, is this right? you can fix this by stop drilling each end of the crack with a 1/8 drill bit, just be careful when drilling making sure you drill only thru the case and you're be alright, then take a rotary file in a drill motor and remove a little material from the crack making a v shape, clean the area with some degreaser to remove any oil residue, fill in the crack with JB WELD , this will permanently fix the crack.
if you choose not to stop drill the ends of the crack it will contuine to crack . stop drilling is important to permanently fix this area, the other alternative is to remove engine and replace the left hand side case.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
