new 07 trx450er header prob
i just jetted my brand new quad with a dyno jet kit to the specs. it got rid of the bog and has excellent power now i also put a new fuel screw in also. i noticed that when i put it in neutral the header was bright red from the heat the fan will kick on and off and you give it throttle it really turnd red the over heat light doesnt come on. it just seems that the header gets real red is that normal or am i missing something im still running stock header and pipe till i can afford a new set any help or suggestions please
I understand the header material is made out of something different (thinner) and gets hot faster. This is soposed to be normal and will not hurt anything. Did you also bump up your piolet jet? Do you have the airfilter lid off?
juanmortiz92
Jul 21, 2015 04:10 PM
