new 07 trx450er header prob
Old May 7, 2008 | 11:52 PM
donkypuncha's Avatar
Default new 07 trx450er header prob
i just jetted my brand new quad with a dyno jet kit to the specs. it got rid of the bog and has excellent power now i also put a new fuel screw in also. i noticed that when i put it in neutral the header was bright red from the heat the fan will kick on and off and you give it throttle it really turnd red the over heat light doesnt come on. it just seems that the header gets real red is that normal or am i missing something im still running stock header and pipe till i can afford a new set any help or suggestions please
Old May 8, 2008 | 12:06 AM
drillerrich's Avatar
IF YOU PUT THE JET KIT IN CORRECTLY... DID YOU ADJUST THE FUEL SCREW TO SPECS?
Old May 8, 2008 | 12:15 AM
yes it said to adjust adjust 1.5 turns out
Old May 8, 2008 | 02:11 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Assuming you aren't running lean....don't sit around with it idling and getting hot. Get moving and that header will cool off....
Old May 8, 2008 | 12:01 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
I understand the header material is made out of something different (thinner) and gets hot faster. This is soposed to be normal and will not hurt anything. Did you also bump up your piolet jet? Do you have the airfilter lid off?
Old May 8, 2008 | 12:46 PM
lefty1's Avatar
What RR said. When I let mine sit and run, especially when it is dark, my pipe is flaming red...let er' out and run!!
Old May 8, 2008 | 10:11 PM
the pilot jet is still the same should i bump it up and the box lid is still on without the snorkel
BigCam
Sep 16, 2015 01:53 AM
Bigtwin700
Sep 9, 2015 09:32 AM
toonces
Aug 5, 2015 05:55 PM
zach1106
Jul 31, 2015 01:55 AM
