1999 Bear Tracker Questions
Old May 8, 2008 | 09:04 PM
jdennysgirl's Avatar
Default 1999 Bear Tracker Questions
I have acquired a 1999 Bear Tracker. It seems to run just fine. My husband seems to think there is gas leaking from the bottom of the bowl. Any ideas why this would be happening?
Also when on a hill I can't figure out how to brake the atv. Even in gear it still rolls. Any help would be appreciated. Thank you.
Old May 8, 2008 | 09:11 PM
jflib74's Avatar
most of the time the float is stuckin the carb and it keeps filling with fuel as to the brake im not familair with that machine
Old May 8, 2008 | 09:16 PM
O.K. so I am really dumb here. I don't know a thing about any of this. Are you saying this is normal or do we have a problem? If so what do we need to do to fix it? Also, thanks for the really fast reply.
Old May 8, 2008 | 10:29 PM
jflib74's Avatar
The carb needs to be taken apart and cleaned it is a problem. If you never have done it before you might want to have someone do it. Or if you feel good get a manual for your quad and it will help you.
Old May 9, 2008 | 07:03 PM
yamaharap's Avatar
or mix in a little carb cleaner treatment made by lucas i think with your gas and let it run a little while i might fix the problem i has on mine before
Ean
Dec 19, 2022 08:48 AM
austinwhitton
Aug 11, 2015 06:21 PM
akbrewcrew
Aug 9, 2015 10:54 PM
kdg723
Jul 25, 2015 01:20 PM
Chuck188
Jul 17, 2015 02:45 PM
