need help guys! wiring issue
Old May 11, 2008 | 11:01 AM
furnaceman's Avatar
Default need help guys! wiring issue
I have a 99 sp 500 non ho that has the issue with low to no spark only sparks sometimes. i ohmed out the pickup coil and got 100 ohms. I ohmed the stator and got 3.6/698 ohms. It looks like the stator was replaced before at some point. I have a yellow wire and a yellow red stripe wire that are down by the stator and are not hooked to anything on the stator. I think I have a bad stator but am confused about seeing only three wires hooked up to it and the other two doing nothing. I did find some cracks in the coating on the stator I was going to put this up for sale today to buy my new sp500. So I need help fast.
Old May 11, 2008 | 12:27 PM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: furnaceman
I have a 99 sp 500 non ho that has the issue with low to no spark only sparks sometimes. i ohmed out the pickup coil and got 100 ohms. I ohmed the stator and got 3.6/698 ohms. It looks like the stator was replaced before at some point. I have a yellow wire and a yellow red stripe wire that are down by the stator and are not hooked to anything on the stator. I think I have a bad stator but am confused about seeing only three wires hooked up to it and the other two doing nothing. I did find some cracks in the coating on the stator I was going to put this up for sale today to buy my new sp500. So I need help fast.</end quote></div>
I don't have a manual here with me but the yellow wires are for the charging system. The ohms readings you posted seem close(don't have a book to verify, they're at work) The other wires have to do with the ignition side. It seems really odd the yellow ones are not connected to anything. That can't be right in my opinion.
I believe the reverse limiter is in the speedo on that machine. Try unplugging the speedo and see if anything changes.
Old May 11, 2008 | 09:22 PM
furnaceman's Avatar
ok I took out the stator today cleaned it up reinstalled it and she fired up ran for a few minutes started it up about five more times parked it out front for sale just went to bring it in and it ran then stalled and would not start again! I'll try the speedo trick.
Old May 11, 2008 | 10:27 PM
furnaceman's Avatar
Well I found tonight that when I turn it over and hold the plug to groung I get a weak spark from the end of the plug to the frame not from the electrode to the end. I'm stumped on this. I even tried with a new plug and still no go. what do you guys think this wheeler is worth not running?
txkevin
Sep 21, 2015 02:02 PM
BEEFKING69
Jun 17, 2015 12:38 AM
jag6510
Jun 15, 2015 05:59 PM
wildbill59
Jun 9, 2015 02:28 AM
OLDSTER
Jan 9, 2001 10:13 PM
