Warrior forward/reverse lever question...
Old Jan 21, 2001 | 09:09 PM
mlsmls's Avatar
I have two questions for fellow warrior owners.
1. Has anyone had trouble with their forward/reverse lever causing their machine to ro not rev? I think that there must be some kind of electrical connection that prevents the machine from doing anything but idle when this lever isn't fully engaged. My warrior would go in gear, but would sputter and pop when you tried to rev beyond idle. Has anyone else had this problem and what did you do to fix it?
Old Jan 21, 2001 | 10:35 PM
racer_x's Avatar
I had a similar problem. The reverse must be grounded. I took the assembly off the quad and sanded the frame and back of the assembly and it now works fine. You could also run a ground wire if you wanted.
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
